Coil Resistor Wire Subsitute
qmcdugan
Post by qmcdugan »
The truck is a 70 F100 with a 1970 351C.
Needed: a Part Number, if therer is one to be had.
Might there, be a suitable Ballast Coil Resistor Block replacement, for the Original Resistor wire? Getting the right one or one that works,
is difficult as there are no markings on the block that I tested and removed today.
The following is the procedure I used during testing of the Resistor that looks like an RU38, listed on O'Reilly's web site.
FIRST: Check the Battery voltage. Should see about 12v
Next: Testing the Ballast Resistor Block. Disconnect the INPUT wire that comes out from the firewall to the Block. Connect the RED
test lead to the INPUT wire and the BLK lead to the ground cable (that’s right there). Should see 12v. Yes? Good.
Next: Re-connect the INPUT wire to the block and disconnect the OUTPUT wire from the block and connect the RED test lead
to the exposed tab on the block. Should see 6-10v.
NO? 12v? That means the Ballast Resistor Block is shot, get a new one.
At the end of the day, I have a STANDARD brand RU11 Resistor block installed. It's a bit of a crap shoot as to wheather it will continue to work.
With the engine running, I'm seeing 10.1v at the POS terminal on the Coil. Oh and I installled new condenser and points, gap at .018.
70 F-100 Sport Custom, 84 Camaro SportCoupe
sargentrs
Re: Coil Resistor Wire Subsitute
Post by sargentrs »
Replacement resistor wires are available at a varity of places. Search for C0LF-12250-A or Motorcraft DY-37. You're local parts store may be able to order one for you crossreferencing the Motorcraft number. Here's one from NPD. https://www.npdlink.com/product/resisto ... ied/101401
qmcdugan
Post by qmcdugan »
SARGENTRS
Thanks for the link. One is on the way.
It's still running and its day two on the, STANDARD RU11, ballast resistor.
