Gear Ratio
Moderator: Doug Comer
- broke_okie
Gear Ratio
Well I bought a detroit locker for my 9" and want to change the ring and pinion to support 36" tires. I am currently running 3.50 gears with 33's . I was told 4.56 would be good.....I thought 4.88 would be good......I very rarely have to go over 55 mph for short distances so I thought 4.88 would give me good grunt up hills...since I pull my camp trailr up the side of the mountain all summer and during deer season also it would be good offroading . Does anyone have any suggestions...Heep I know you proly know.Thanks
J.P.-"Happiness is... not being smart enough to know what to worry about."
** 1971 F100 SWB 4X4 SPORT CUSTOM**
- heep70
re: Gear Ratio
This is going on your trail rig?
As long as you don't depend on the rig on the highway I would at the least run 4.86 or even 5.13. Detriot will do you good, but I would save the cash and either put a full spool in or weld it. Why mess around is what I say.
http://www.ring-pinion.com/content/prod ... id=3&pid=4
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 68half/step4x4
re: Gear Ratio
For what you want, either sounds pretty close. 72highboy posted this link the other day. check it out.
http://www.onandoffroad4wheeldrive.com/ ... _guide.htm
If it's too loud, you're too old!!!
- broke_okie
re: Gear Ratio
Yep mainly offroad...it sees occasional road to get there but I do not wanna weld it or spool it due to pullin my trailer.Ihad that done to a rear once and when i pulled heavy loads i busted shafts on a dirt road.
- heep70
I would go with the detriot or save a couple more dollors up and get an ARB.
Better yet, bigger axles. :twisted:
Greg
