1967-1972 F100 and F250 Parts
I parted out some different trucks and currently have the following parts leftover
1970 F250 XLT Ranger 2WD was factory A/C truck, 360 w/ C6:
Factory AC setup complete from under dash assembly-$500
Rear window-$50
Chrome headliner trim-$40
Ranger glovebox door-$25
Automatic brake pedal setup-$100
Steering column cover in white-$10
White ashtray-$10
Windshield wiper motor w/ linkage-$15
Power Steering Gearbox w/ pitman arm-$150
1970 F100 Sport Custom 302 w/ 3pd On the column
Gauge cluster-$25
Manual steering gearbox-$10
Yellow ashtray-$5
front drum brake backing plates (set)-$25
Inner door handles (set)-$10
Door hinges (set of 4)-$20
Front radius arms-$25
I have another rotted out 1970 F100 302 w/ 3spd Custom that I'll be parting soon too. Have more parts probably tucked in the garage, so if you're looking for something that you don't see, just ask! Located in Cochranville, PA 19330.
Thanks Jacob
Rear window-$50
White ashtray-$10
Gauge cluster-$25
Yellow ashtray-$5
Thanks Jacob
Last edited by performancewhite302 on Wed Sep 08, 2021 11:20 am, edited 2 times in total.
Re: 1967-1972 F100 and F250 Parts
Can you post a Pic of the wheel covers?
1967 F-100 4x4 custom cab.
I am after an XLT bench seat medallion.......
Thanks
Thanks
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
Busboy-yes, I'll get some up tomorrow of them
Chriscris-are you looking for the XLT woodgrain seat emblems?
- colnago
The title says 67 - 72. Do you have a '67 driver door latch mechanism?
Joseph
Joseph
Busboy- took a lot longer than I anticipated to figure out how to resize the pictures of the hubcaps to upload, sorry for the delay!
Colnago- I don't have a 67 door latch mechanism at this time, but if I get one I'll message you
Do you still have the interior headliner trim?
What is the condition of the drivers side tank? Would like to see pictures of it and the instrument cluster.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
Delta nine-yes I still have the headliner trim
Disneyspatb-I’m away for a few days but when I get home I’ll get some pictures of the tank
Thanks!
Thanks!
If Delta-nine does not get the headliner trim, can I be 2nd in line? Also, do you have the rear cab trim that starts on the sides and goes around the back, like for two tone cabs?
thanks
thanks
Zorm- I don’t think I have the rear trim but I may have another set of the headliner trim. I’ll check my stash and let you know
Sweet can I get some pictures when you get back?performancewhite302 wrote:Delta nine-yes I still have the headliner trim
Thanks!
Does the yellow ashtray have the 4 balls on the side?dm sentperformancewhite302 wrote:I parted out some different trucks and currently have the following parts leftover
Black Automatic steering column (non p/s) with steering wheel-$200
OEM black dash pad with no splits or cracks (2 tiny indents on the driver's side and one stud is rusted)-$340
OEM Chrome front bumper-$75
In cab fuel tank-$10
Driver's side fuel tank with brackets, switches and skid plate-$150
OEM front fenders (rust down low behind lower molding)-$150
Woodgrain surround gauge cluster-$50
Woodgrain/black door panels with white paint surround-$125
Hood hinges (set)-$10
Factory AC setup complete from under dash assembly, smaller glovebox insert, HVAC controls, pass side fresh air vent, lines, compressor, condenser, pulleys, FE fan, FE fan shroud and 3 groove FE crank pulley. (There is one crack in the plastic for the under dash unit and the condenser is finally separating due to age)-$1000
Rolling chassis (has front suspension and steering linkage intact, Dana 60 with 4.10's out back. No motor stands, no sheet metal, just a solid old frame with an extra cross brace welded in the rear)-$350
Rear window-$50
Rear window trim-$75
Front windshield trim (one small ding otherwise very good)-$100
Headliner (it's warped but still could be good for a template, board is solid for its age)-$10
360 2bbl with C6-$700
2 piece driveshaft-$15
Large woodgrain tailgate panel w/ tailgate (woodgrain is faded but the panel is in good shape with a few minor dings)-$400
8' bed woodgrain upper trim pieces (woodgrain is faded but fairly straight pieces for coming off a truck)-$160
Automatic brake pedal setup-$120
White ashtray-$5
1970 F100 Sport Custom 302 w/ 3 spd:
Yellow and green Sport Custom Door Panels-$100
Gauge cluster-$25
Green 3 on the tree steering column with steering wheel-$100
15" full wheel covers (set of 4)-$50
Heater box-$10
Yellow ashtray-$5
Hood hinges-$10
302 Distributor-$10
Thanks Jacob
do you have any of the 4 rib lower trim? I just need one piece, the lower passengers fender
thanks
thanks
performancewhite302 wrote:Disneyspatb-I’m away for a few days but when I get home I’ll get some pictures of the tank
Thanks!
![Worthless without pics :nopix:](./images/smilies/icon_worthless.gif)
Cluster too please.
