I have a 1972 F100 that I have swapped in a 78 Bronco front axle. along with a 2" coil lift from SkyJacker.
will the stock steering Drag Link form a 78 Bronco work? also, with the steering wheel centered.
or will I need a longer one?
Thanks
after this comes the Brakes... oh joy..
Stock Drag Link question
1972 Ford F100 SWB 4x4
- basketcase0302
Re: Stock Drag Link question
At 2" you are on the borderline of needing the adjustable drag link. I added 6" to the suspension of om EB and had no choice but put one on."rbmead"]I have a 1972 F100 that I have swapped in a 78 Bronco front axle. along with a 2" coil lift from SkyJacker.
Thanks after this comes the Brakes... oh joy..
But it is money well spent as if you've already done the lift you've noticed your steering wheel no longer turns to the right as far as it does to the left. The adjustable;e drag l;ink takes all the variables out of the equation and lets you fine tune the front steering as it should be.
There are many...other brands of them, II bought one from the Graveyard that lasted me another 15 years of wheeling.
http://www.ntwonline.com/77-79-FORD-F25 ... 15415.aspx
Looks like that will be on my Christmas list. along with Radius drop brackets..
Thanks for the info.
- basketcase0302
I drove my EB with a 6" lift kit in it for only a few miles, (they have a habit of the old Ford saying "doglegging" down the road without the proper drag link ) before ordering the adjustable from i believe James Duff.
There's several different folks that make these to so shop around for the best price and best one.
- Manny
I will jump in and pretty much second basketcase. Have lil red my 74 bronco. Has 2.5 under it with stock stuff. 2 inch 2.5 inch is the borderline for needing upgraded adjustable stuff. Lil red turns harder one way than the other and the front axle is off center just a little. It's the war to be waged with them. That's an ancient rancho kit probably late 80's so it was not as precise as the good parts your can get now and make a perfect front end.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
