I just posted two more pages to the Parts Numbers Index, which includes numbers and specifications for the coupling shaft, which is Ford's term for the driveshaft between the transmission and carrier bearing.
Coupling Shaft - F100 (2WD & 4WD)
Coupling Shaft - F250 (2WD & 4WD) & F350
These two pages, in addition to the driveshaft PN pages which were also just posted, will now allow you to accurately determine driveshaft specs for all '67-'72 light-duty trucks...everything between the transmission and rear axle (and the front driveshaft for 4WD applications). This will come in handy when trying to find a replacement or when contemplating an engine and/or transmission swap.
PN's listings update: Coupling Shafts
