fuel gauge from a bronco II
- 68ford
I can pick up a bronco II fuel tank with fuel sending unit for free. i was wondering if the sending unit would work for my behind the seat tank? and if anyone wants the tank they can have it if I pick it up.
"Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young."
Henry Ford
Henry Ford
re: fuel gauge from a bronco II
Hmmmm...I believe the sending unit values would be the same, but I have my doubts that the float arm is long enough. I mean, it would probably work and read 'Full' when the tank is filled up, but with a shorter arm, it's going to read 'Empty' fairly quickly....maybe at about the half-tank point? I'm not entirely sure though, since I've never seen a Bronco II tank/sending unit. However, shallow tanks have short arms on the sending unit, while deeper tanks (like our behind-the-seat tanks) have longer arms.
- 68ford
aahhh, very interesting. I was telling my wife i was thinking about the same thing, just not to the degree you were able to explain. i may try it and maybe rig the arm to be a little longer somehow? I hate to pass up the free stuff.
do you think i could just replace the bronco arm with my sending unit arm somehow?
Henry Ford
Henry Ford
Is the Bronco II sending unit a top- or side-mount?
Yeah, I suppose you could always braze an extension onto it, but to be honest with you, I think you'd be happier replacing yours with the correct part. Those are a dime a dozen at the local U-Pull-Its. Heck, I've even got a few of them laying around.
- 68ford
im not sure....yeah i think you're right, i'll just get another from somewhere else. thanks....
Henry Ford
Henry Ford
