460 crank questions
- OldRedFord
460 crank questions
Will there be any issue if I use the set of pulleys I have that were mounted on a engine with a short crankshaft snout, on one with a long snout?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: 460 crank questions
more than likely the rest of the pulleys wont line up properly. because the snout will let the pulleys set out further from the engine. i would bet all the pulleys have the same depth but its snout size that matters. didnt i hear a girl say that once about someone she was dating?
