Oil pump installation
mjhaltom
Post by mjhaltom »
Does the oil pump driveshaft have to be installed from the bottom when the oil pump is bolted in or can it be put in from the top along with the distributer?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
Thunderfoot
Re: Oil pump installation
Post by Thunderfoot »
It has to be put in from the bottom with the oil pump. There is a spring type retainer ring around the pump drive shaft to keep it on the pump, under the lower boss in the block for the distributor so that when you pull the distributor it stays in the oil pump. There is nothing to hold it to the bottom of the distributor to try to install it from the top and nothing to help guide it into the oil pump... would be almost impossible to get it into the pump from the top :wink:
Shayne
mjhaltom
Post by mjhaltom »
Thanks. I got it put in.
1989 Ford F150
Well, I'm glad you have it taken care of, but for the record.
It does NOT have to be put in from the bottom, it probably should be...
Nonetheless it is quite common to remove the clip (which is close to worthless anyway) and drop them in from the top.
