Problems with carb
ares360
Problems with carb
Post by ares360 »
I have a 71 F250 with 360. When I start it, it doesn't want to keep running unless I press on the pedal for about a minute, then when I shift it goes straight into high idle. I know it isn't the tuning because it just started doing this after 3 months of continous driving. Any ideas? Thanks
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
sideoilerfe
re: Problems with carb
Post by sideoilerfe »
more information needed. What kind of carb is it? sounds like a choke issue. 71 should have a hot air choke unless converted.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Wes
Post by Wes »
Sounds like a rich run condition, check your choke operation and float level
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
ares360
Post by ares360 »
I don't know what kinda carb it is, I am pretty sure it is the orginal one. I know it is wide open.
ares360
Post by ares360 »
anybody have any suggestions?
Kane
You are going to have to get us more information. "original" could be an autolite or holley 2v.
That said, wes gave you the most possible causes. but to get much more specific we are going to have to know what we are working with.
Do this though.
remove the air cleaner top
press the accelerator pedal to the floor twice and let it up slowly.
(is the choke plate closed)
Start the truck (or have someone start the truck)
(is the choke plate still closed, but cracked about 1/4-3/8 inch?)
Warm the truck up
(is the choke plate open?)
Needless to say, keep yourself and clothing clear of moving parts....
