#13 - Aug. 4, 2007
How's your Ford truck parts knowledge?
FORDification
Site & Forum Admin
Site & Forum Admin
#13 - Aug. 4, 2007
Post by FORDification »
I've kinda lapsed in stumping you guys with Truck Trivia, so I'm going to try to get this going again...at least once a week.
For this one, I can't give any clues without giving it away. Just identify these screws....where they're used (and give the specific application). Good luck! :thup:
rjewkes
Post by rjewkes »
carburator screws. used on the power valve cover. I've also seen them on the choke thermostat.
fuelly.com
FORDification
Site & Forum Admin
Site & Forum Admin
re: #13 - Aug. 4, 2007
These are way too big for that. ;)
kaptnkaos
Post by kaptnkaos »
They look like the same size and length as the ones that mounted the oil cooler to the rad support on the '71 CS I dismantled.
If so, they were a bugger to get out.
KaptnKAOS
Wes
Post by Wes »
oil pump cover plate on your 460
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
ToughOldFord
Post by ToughOldFord »
Cam plate screws?
kaptnkaos
Post by kaptnkaos »
Dietz (?) Front fender marker light screws
KaptnKAOS
rjewkes
Post by rjewkes »
hmm i thought it was just a close up shot.
fuelly.com
ezernut9mm
Post by ezernut9mm »
jeez, i know i have seen those before, but i can't remember where. i know that they are countersunk, and i was thinking there were three of them. :cry:
rjewkes
Post by rjewkes »
vent window screws hold the vent window frame to the front of the door.and there are three and they are a bugger to get out. there is a forth screw in the door pannel but it is a trim screw.
fuelly.com
FORDification
Site & Forum Admin
Site & Forum Admin
Re: re: #13 - Aug. 4, 2007
ToughOldFord wrote:Cam plate screws?
YES! These are the camshaft plate retaining screws on an FE. :clap: :thup:
All good guesses though!
ToughOldFord
:woohoo: I got one! :D
What made me guess that way was mainly the look of the oily buildup on them. That told me they were probably internal and there aren't very many screws on the inside of an engine. So I was thinking the cam plate or maybe oil pump related, but IIRC the oil pumps are assembled with bolts too. And the cam plate uses those screws because bolts interfere with the sprocket. (I learned that last part. :doh: )
kaptnkaos
Post by kaptnkaos »
maybe a dumb question now that I know what they are...
Where are they located?
I don't recall ever seeing that piece on my truck...
Are they behind the cam gear, behind the timing cover?
If that's the case... I ain't never seen them screws b-4
KaptnKAOS
ToughOldFord
kaptnkaos wrote:maybe a dumb question now that I know what they are...
KaptnKAOS
Yep, that's where they are!
FORDification
Site & Forum Admin
Site & Forum Admin
:yt: Since a picture's worth a thousand words:
This is the view after removing the timing cover, and then the timing gears/chain.
