- hfdco4
I got some motivation for Christmas. My wonderful wife bought me some stuff for the garage. I got a nice welding jacket, File Set, Face Shield and a small Belt Sander. I am a very luck guy for sure!
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
1970 F250 4x4
- Venomous duck
Great score. Motivation is the best gift.
- hfdco4
Got back out into the garage. Made some progress as I found the actual spacer provided with the New Harmonic Balancer. I pulled out the one I made and installed the correct one, belt alignment is perfect now. I moved a tool box and cleaned some stuff of my workbench, so now I have great access to the front of the truck.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Picked up Insulation from Eastwood also grabbed a Flaring Tool while I was there.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Small update and progress. So I finally got back out into the garage. I pulled the Headliner Moldings and sanded the rust off them. I decided to try and paint them a semi-gloss black. They will look good against the ABS Plastic Headliner I have.
Now I can put those aside and start on Cab Insulation.You do not have the required permissions to view the files attached to this post.
FE390PC
1970 F250 4x4
1970 F250 4x4
- Fordkid68
That trim looks great!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
- hfdco4
Yes, It went from trash worthy to very usable in short time.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Since the trim came out so good, I figured the Brake/Clutch Assyria needed to be done. I pulled it all apart and cleaned it up. I sanded and painted all the pieces. Last week I ordered all the bushings and a new stop from Dennis Carpenter. I do have to weld the Clutch Rod as one end has a groove worn in it. Thursday I am going to start the reassembly. Pictures to come soon.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Here are the before pictures.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
With the pedal ass'y painted, its time to pull out the old unit.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Since I made some progress I figured I would keep moving forward. I ordered parts for my power steering pump refresh and also ordered a new sending unit for the rear tank I am installing. Small steps but at least I am going forward for the moment.
FE390PC
1970 F250 4x4
1970 F250 4x4
Good to see you are making more progress, it helps motivate me to keep working on my truck. Your clutch and brake assembly looks great! ![Cool 8)](./images/smilies/icon_cool.gif)
- hfdco4
More progress, I pulled my Fuel Tank out of storage. Painted the bottom and tested my Fuel Sender. Found that the sender I had will not work so bought a replacement on Amazon. Made a couple of mods and it's installed. Works with my gauge as well. I got the skid plate down and found that I needed to do some additional cleaning and some recoating. Tomorrow I will get the tank and skip plate fully coated. Once dry I am going to work on the install.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Here are the pictures of the Tank and Skid Plate.
FE390PC
1970 F250 4x4
1970 F250 4x4
- hfdco4
Started getting the upper tank straps located on the frame. Right now I have the tank supported in place so I can drill holes. Small steps, but right now they are at least forward!
FE390PC
1970 F250 4x4
1970 F250 4x4
