popeyes71
Post by popeyes71 »
Looking good! Thats pretty cool how the foam is still good. Over the years it usually it just rots away.
-Popeye-
1971 F-250 4x4 Highboy
hfdco4
Post by hfdco4 »
Here is my refurbished heater box. I have some roof dents to tackle next and some dents in the back of the cab to work out. Once those are done I will start working on the passenger door. Well here is the heater box.
Actually came out great.
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
sargentrs
Post by sargentrs »
Great work! :thup: 8)
hfdco4
Post by hfdco4 »
Thanks Randy!
:fr: FE390PC
1970 F250 4x4
popeyes71
Post by popeyes71 »
Looks brand new :thup:
-Popeye-
hfdco4
Post by hfdco4 »
Thanks Popeye. I am trying to make all the systems as good or better than original.
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Started working on the braking system.
I believe this is a dual diaphragm unit.
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
I also have the master cylinder/booster from a 1979 f250. I noticed that there is an offset arm for increased leverage. I wonder if I can use the lever arm on the 8" dual diaphragm booster? This would increase pressure on the master cylinder while keeping the pedal pressure reasonable? And since I have the 1978 f250 front axle with dual piston calipers I think I need to use a 1.25" bore master cylinder.
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Well, digging into the 79 brake booster revealed that its junk all the way through. So I will continue cleaning the booster I have and look at a 1995 explorer.
:fr: FE390PC
1970 F250 4x4
popeyes71
Post by popeyes71 »
Yep, thats what you have, a dual diaphragm brake booster. They were on the heavy duty trucks. And you are correct on the master cylinder. With the big dual piston calipers you'll want the larger bore master cylinder. I'm not familiar with the newer style brake booster with the lever arm. It could help with the action but I'm not sure how well or if you could adapt it to the truck??? Hopefully someone on here has some experience with them.
-Popeye-
hfdco4
Post by hfdco4 »
Yeah, the lever is a dead issue. It was rusted beyond use!
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
So I went and picked up some parts today. I got another known good booster and master cylinder. I also got a pto driven Holmes Wrecker winch. This thing is a beast. A member over at FTE was scrapping a 1970 F350 Wrecker after pulling the motor.
:fr: FE390PC
1970 F250 4x4
sargentrs
Post by sargentrs »
:thup: 8)
popeyes71
Post by popeyes71 »
Score! :woohoo:
-Popeye-
hfdco4
Post by hfdco4 »
Working on hunting gathering now. Trying to find parts i have squirreled away so they can start to be cleaned up and re-installed. I did move the chassis over next to the garage.
:fr: FE390PC
1970 F250 4x4
