- hfdco4
So no luck finding my lower Column support bracket.
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- hfdco4
Glad we are back online!
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Got the Bed and Hood installed and started loading parts into the bed. The pending move is coming along fast!
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Been a long time since this was in this state.
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- jzjames
Gettin’ there is half the fun, right?
- hfdco4
It is a little overwhelming to get all this "stuff" packed and moved about halfway across the country. But the move is a good thing.
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Got more cleaning done. Installed the tailgate and got the extra bed flipped over onto a trailer. Just have to make some stakes so i can drop the bed onto the truck for shipping. Decided I am going the scrap the 360 and the extra T-Case as room is at a premium.
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Loaded up the 360 and the parts Dana24 T-Case as well as a bunch of other scrap. Got to the scrap yard and found out I had grossly overloaded the poor F150. I had 2200lbs of scrap steel and about 100lbs of other materials. Unloaded the truck and left with $178.00 more in my pocket. Once that was done I took a good look at my spare bed. Well it was in much worse condition than I had thought. I ended up cutting a large section of floor out and both wheel tubs. The rest made a trip to the scrap yard but only had 500lbs so the payout was much less. Been looking at shipping companies for when the Truck has to be moved. I don't think I want to try and tow it behind the U-Haul truck from MD to MN.
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Cut up my extra bed, turns out it was in far worse shape than I had thought. I kept a section of the floor and both wheel wells. The rest went to the scrap yard. Today I plan on getting into the attic of the garage and pull down a bunch of stuff to go through.
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
