hfdco4
Post by hfdco4 »
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
hfdco4
Post by hfdco4 »
cab on frame
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
As it sits today after a lot of cleaning
:fr: FE390PC
1970 F250 4x4
Fordkid68
Post by Fordkid68 »
Looking great!! You'll be driving it before you know it!
Adam
My first truck,
1968 F100 lwb 2wd soon to have a 351w, 5-speed
http://www.fordification.com/forum/view ... 15#p771357
^^Build Thread^^
99 F250 super duty, 7.3 diesel!
04 Subaru Outback (daily driver), with a 2.5l boxer H4
(no other projects, YET!)
"Might be crazy but I ain't dumb"!
hfdco4
Post by hfdco4 »
Plenty more work to do, but thanks for the motivation. I am going to assemble the front of the engine so I can get the 3G Alternator and Power Steering Pump mocked up. Spent a little time on the daily doing some needed maintenance.
:fr: FE390PC
1970 F250 4x4
67mann
Post by 67mann »
:woohoo: :clap: :clap:
hfdco4
Post by hfdco4 »
Got some more cleaning done. Managed to make a fairly large pile of scrap going now. Also got the center top portion of my old core support cut out. I am going to graft it into my 78 core support.
:fr: FE390PC
1970 F250 4x4
LeoZelig
Post by LeoZelig »
Paul, congrats on the milestone! That's gotta feel great!
Hey, did you build the gantry/block and tackle frame for lifting the cab, yourself?
Chris
Project Thread: http://fordification.com/forum/viewtopi ... 22&t=96617
1969 F100 - Roy
SWB
3-on-the-floor and I hope to return it to 3-on-the-tree
360
49k on odometer... actual? Anyone's guess :)
hfdco4
Post by hfdco4 »
LeoZelig wrote:Paul, congrats on the milestone! That's gotta feel great!
Bought it at Harbor Freight, it works great!
:fr: FE390PC
1970 F250 4x4
LeoZelig
Post by LeoZelig »
hfdco4 wrote:Bought it at Harbor Freight, it works great!
Harbor Freight, my new home away from home :D
That's good to know - someday I'll need that kind of gear to take the truck apart.
Chris
1969 F100 - Roy
SWB
360
hfdco4
Post by hfdco4 »
I like HF, you just have to look at what you are buying. They have the super cheap and useless tools as well as inexpensive good tools. I have an engine crane, engine stand, floor jack, the gantry crane and chain fall. I use all of them and they work great. I have also bought jack stands there but never the recalled ones.
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Got some more of my hoarded parts cleaned. I was looking at the axles and realized I only had half of the U-Joint U-Bolts ready to go. I found my container of spares and dumped then in the EVAPO Rust for cleaning. Next is the flipping of the Front Axle U-Bolts. I went to the swap meet in PA and found a set of U-Bolts and Plates.
:fr: FE390PC
1970 F250 4x4
LeoZelig
Post by LeoZelig »
hfdco4 wrote:I found my container of spares and dumped then in the EVAPO Rust for cleaning
I found EvapoRust just before starting this latest project - I love what it does for our old, rusted bits and bobs!
It sounds like I need to start searching out swap meets, too :-).
Chris
1969 F100 - Roy
SWB
360
hfdco4
Post by hfdco4 »
It is a good place to find odd things.
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
I have the last U-Bolt in the evaporust solution now. Hoping it is cleaned up in the next day or two. Then hoping to get them installed this weekend!
:fr: FE390PC
1970 F250 4x4
