76 column in 67
modrisco
76 column in 67
Post by modrisco »
I want to put a 76 column in my 67 truck. What is the easiest plan for the wiring? Will the 67 turn signal switch work in the 76 column?
jimmy828
Re: 76 column in 67
Post by jimmy828 »
don't know if this will help since different years. I switched to power steering in my 69. I used a 74 column. I new the wiring would be a nightmare so i thought i would try putting the 69 shift collar (3 on tree ) and the 69 turning signal switch housing along with wiring on the 74 column just to dodge wiring issues concerning the turn signal switch. By doing that i got rid of the Hazzard switch that is on the 74 column and my wiring was a direct fit to under dash connectors. Everything worked out just fine. If yours is an automatic, i have no clue if it will work but it will be worth a try. :fr:
modrisco
Re: 76 column in 67
Post by modrisco »
That sounds like a good solution. I will try the 67 signal switch in the 76 column, I am going from manual to auto so I want the column shifter. Thanks for the reply.
