shocks on a 1 ton truck?
General Discussion Topic Archives
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
I am putting a Dana 70 rear in my F260, and I noticed that the D-70 does not have provisions for shocks to mount on the axle. were they an option on these? I noticed on my F260's Ford Build sheet, it lists front and rear shocks like they are an option.
see here...
http://fordification.com/forum/viewtopic.php?t=5940
customcrewcab
re: shocks on a 1 ton truck?
Post by customcrewcab »
soon as i saw this post i knew what you where talking about. my crew with the dana 70 did not have shocks. had ac but not shocks. it rode good but is it started it hop it would bounce.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
As far as I know they weren't even available on a 1-ton. Makes sense if you think about it, actually. Shocks were intended to damnpen the bouncing and to keep the rear tires in contact with the road when using a soft rear spring....and with that super-stiff rear spring setup the 1-tons had, you ain't gonna have any suspension bounce! :eek: Well, not like a car or light truck, anyway. Any bouncing you'll be doing will be from the tires, not the suspension.
zakt
Post by zakt »
On my 2wd 67' F350 the shock mounts were (I pulled the D70 and putting in a D60) on the spring plates to the frame.
1972 Ford F350 crewcab
72hiboy4x4
hey are you going to use those U-bolt plates from the D-70?? I need a set for mine!
the D-60's axle tubes are 2.5 inch and the D-70's are 3". I could trade a set for the D-60 if you need 'em!
