heater motor resistor
Is there a resistor that can fail in between the heater fan speed switch and the blower motor? and if there is , where is it?
1969 F100 300/4spd power steering, manual brakes
- 68F250
re: heater motor resistor
Yes, if the fan only runs in the "high" position, the resistor assy. has failed. Unfortunately, it is bolted to the back side of the heater box. You will have to remove the whole thing to get to it. The wire wound resistors get hot so they are located inside.
Barry
- flyboy2610
I believe this is the beastie in question.
Red Green
you'd better be right.
Red Green
- 67F250CS
Hope this pic will help a little. It the part that has the wires attached to it. Two small screws hold it on. You can get to it without taking it out but it is half the time to just remove the heater box and all. If you leave it in your working kind of blind as its between the heater box and the firewall and you have about 2-3 inches to work in.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
thanks a lot
exporitory surgery continues.
Its getting cold in the mornings and I have no heater fan on any speed and the fuse is good .
All this stuff worked when I bought the truck, my electrical system is self destructing
- 68F250
Thanks guys for posting the pics!
67F250CS, I stole your pic if you don't mind. Oldhalftons, you can test the blower motor by itself. See the two wires I'm pointing out? The orange one is the "hot" to the blower and the black one is the blower ground. Try disconnecting the orange wire at that connector. Pull on both sides of the connector, don't yank the wire by itself as you can easily break the resistor assy. Now apply 12 volts so it goes directly to the motor and see if the fan turns. If it doesn't, check the ground wire.
Barry
- 67F250CS
No problem. In fact I was going to put some lines on that photo but the free trial of photoshop has expired.
Any help to any member is fine with me.
- 68F250
Great! I was hoping you'd feel that way.
Since the blower doesn't come on at all I'm starting to believe it's the motor.
Barry
good, the motor looks easier to change
- flyboy2610
The wheel is held onto the motor shaft by a set screw. Soak the hole in the wheel where the shaft is with some penetrating oil, then the wheel should slide off the shaft with a good tug.
Red Green
Red Green
yup, I knew it, I was just hoping to avoid it though.
- flyboy2610
At least you won't have to spend $55-60 replacing the heater motor.
Like I have to.
Like I have to.
Red Green
Red Green
