Edelbrock ?
Edelbrock ?
I'm gearing up to install an Edelbrock RPM intake on my 390 and noticed it does not have threaded vacuum ports for power brakes and transmission like my Weiand does.How did you guys handle this? It seems to have maybe one up front,but that's a long ugly way to run the brake hose.Any thoughts? Thanks,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
Re: Edelbrock ?
Drill & tap at the location of your choosing??
Sucks having to drill/modify new stuff, but if it were easy...everyone would build these trucks
Re: Edelbrock ?
The picture at summit racing had a place for the stock vacuum block on the back #4 runner just like my stock 4V manifold.
Re: Edelbrock ?
Mine has nothing from the carb.back.Is the runner considered a vacuum source for power brakes if I drill and tap there? Also I have my vacuum advance plugged into the bottom front of my carb.would it be OK to tee into that for my transmission? Another option would be is...if it's OK to drill into the rear runner for brakes I can find a vacuum tree for both.Thanks,Calvin
Re: Edelbrock ?
yep, just tap into one of the rear runners. Remember, this is a "pipe" thread fitting. Drill & tap accordingly. Next time you're at the salvage yard, scrounge around & see what you can find for a vacuum tree. Most of the Fords had 3-5 small ports, and one large one for the power brakes.
- 390F100
Re: Edelbrock ?
I actually have the edelbrock performer rpm and the edelbrock carb #1407 on my 390 and I thought that you could just use the larger vacuum port off of the rear of the carb...Is that true???
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- averagef250
Re: Edelbrock ?
Runner vacuum is a poor choice for power brakes anyway. I use the runner port on the FE RPM for PCV and run power brakes and modulator off the large port on the carb base, vacuum advance off the timed vacuum port on the carb.
Re: Edelbrock ?
The factory ran it off the #4 runner forever and a day and my PBs never had a problem even with PVC and scoop vacuum control on the same port
Re: Edelbrock ?
390F100 wrote:I actually have the edelbrock performer rpm and the edelbrock carb #1407 on my 390 and I thought that you could just use the larger vacuum port off of the rear of the carb...Is that true???
Yes but that really is the late factory PVC port it is the same as the manifold vacuum so no problem.
- 390F100
Re: Edelbrock ?
Awesome, when I saw this post it scared me cause I didn't and or wasn't going to be tapping a hole into my nice, new and shiny Performer RPM intake...
2007 Suzuki S40 650
2007 Suzuki S40 650
Re: Edelbrock ?
Thanks Guys for all the replies.
Re: Edelbrock ?
390F100 wrote:Awesome, when I saw this post it scared me cause I didn't and or wasn't going to be tapping a hole into my nice, new and shiny Performer RPM intake...
yeah, but when it's done right, and no one notices it...it gives ya that good feeling
- 390F100
Re: Edelbrock ?
I can promise you this, If I would have tapped it, people would have noticed. That is why my truck is going to Hancocks Garage in Eloy,Az for all the body and paint as well as the suspension and anything else I don't want to tackle. This guy here charges 40 bucks an hour plus materials, I think that's a great deal...
2007 Suzuki S40 650
2007 Suzuki S40 650
Re: Edelbrock ?
You have the right attitude. I keep having my tools stolen so the real serious work I am needing done will go to the shop.
