oil pumps
aramil
oil pumps
Post by aramil »
what is more benifical for an fe oil pump, high volume or high pressure.
i want to upgrade the oiling systrem because i was always told that it and the heads are an fe's biggest weakness.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
Re: oil pumps
Really, there is nothing wrong with either the oiling system ot heads for anything but an all out racing application.
Check out:
http://www.doveengineparts.com/documents/26.html and follow the "Insights Into The Ford FE" and "Tip's On Building An FE" links.
Also gess ford machine did at one time have a great article on the oiling suystem... but I'm having trouble finding it...
aramil
Re: oil pumps
Post by aramil »
this is just what a family member told me, he was refering to the oiling system and high rpms for long durations.
that sight has some good historical info too, i learned even more about the 427 then i ever knew,
and from what im understanding, its not the pumps, its the passageways.
Re: oil pumps
The old gess ford machne article did explain how to modify the oil pump passage.
Assuming we are talking about a a street engine with normal clearances I would probably just go with a standard pump a good oil pan and some #90 jets in the head passages.
