2.5" vs 3" pipe size for high powered FE; which is better?
Good morning,
It seems that the two potential choices for exhaust pipe size for my high powered FE project are 2.5" and 3".
As I understand it, 2.5" will provide more low RPM torque, less high RPM flow, and less noise.
And 3" will provide less low RPM torque, more high RPM flow, and more noise.
Naturally this choice is a matter of preference, but what are your inclinations and why?
My initial inclination is to go with 2.5" pipes, since I like quiet and I'm thinking of using Borla mufflers (which only seem to come in 2.5").
Thanks very much!
Thanks very much!
- sideoilerfe
re: 2.5" vs 3" pipe size for high powered FE; whic
If you go duals, then 2.5.
Honestly, I think a 2.5 into a single 3 is your best bet for lowend torque but your exhaust alone isn't going to give you noticable power unless your motor is at least mildly built.
On a stock motor like a 360, you have a single 2 inch tailpipe. I changed mine to a 2.5 because it didn't like going over 70. That made a noticable difference at about 55-60 MPH but in the lower RPMs it stayed the same. If I would've went to Dual 2.5 with Borla or Dynomax mufflers, I would've gotten the same results.
I had a 65 F250 Camper special with a 352. When i bought it It had an exhaust leak from hell and the manifolds were broken. This engine ran great! it had plenty of power. People thought I had a 390. I was 19 at the time and thought, "I'll put headers on it and I'll have even more power." SO, I put headers on it and 2.5 duals and Dynomax mufflers and it sounded so much better but it made NO difference at all in performance.
Unless your engine is pushing 350+ HP, a fancy exhaust isn't going to make a big difference.
- td
i put 3'' pipe on a stock 360 one time before i learned any better, and it absolutely killed the bottom end power. in my opinion 2.5 inch pipe is good for 400 ponies, probably even more.
- mrtleavitt
Dual 2.5" pipes are the way to go. That's what I run on my 390 and my brother just had a professional "X" style exhaust built for his radically built 390. The owner of the exhaust shop explained it to us and that's the best setup he said. He runs it on his 600 hp chevy as well. 3" dual would be over kill and non-profitable. If you are going single, then the 3" would probably be better, but I say duals all the way!
- rubiranch
I don't really know which one is best.
I installed a new cam and a set of Heddman Hedders. I chose a 2 1/4" Y-pipe into a single 3" exhaust. I chose a Magnaflow muffler and a mandrel bent tail pipe than exits just like it did when it was stock
I am 100% please with the sound and performance. I have no idea if 2 1/2 dual would perform better but I was told if it did I couldn't tell the difference by the seat of my pants.
I would think that 3" duals are too much for a 390.
- F10YRB12118
robroy,
Great questions, same one I was starting to mull over.
What kind of 400HP FE motor did you order from Proformanceunlimited? 360, 390, 410, etc.?
I'm working on rebuilding my 360 and I'm learning all sorts of good stuff from your post.
Have you decided what brand of header yet? I have Hooker Comps on my Bronco 302 and they're nice.
Yours,
Yours,
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
Re: re: 2.5" vs 3" pipe size for high powered FE;
Hi Td! Does this mean you put on a single 3" pipe or dual 3" pipes? And about the 2.5" pipes, do you mean single or dual?td wrote:i put 3'' pipe on a stock 360 one time before i learned any better, and it absolutely killed the bottom end power. in my opinion 2.5 inch pipe is good for 400 ponies, probably even more.
Thanks very much!
Hi F10YRB12118! Thanks for your reply; it's nice to know I'm not the only one benefiting from all the great advice that I receive!F10YRB12118 wrote:robroy,
Yours,
This is the 390 motor I bought from Proformanceunlimited, with a few minor upgrades (Edelbrok high flow water pump, Moroso oil pan, and Ford "Cobra" valve covers):
http://www.proformanceunlimited.com/spe ... 425hp.html
I haven't picked out the headers yet. Steve at Proformanceunlimited recommended Hedman headers to me on the phone, but I was planning on starting a forum thread about headers (if I can't find one burried in the forum history somewhere). Thanks for the recommendation on the Hooker Comps; I'll check those out.
As for the rest of the exhaust, it seems that Borla Turbo XL mufflers and dual 2.5" pipes (mandrel bent) is what I'm looking at.
Thanks F10YRB12118!
- sideoilerfe
Dual 3" is overkill, I agree. But single 3" or dual 2.5 with an "X" if you've got the ponies for it.td wrote:i put 3'' pipe on a stock 360 one time before i learned any better, and it absolutely killed the bottom end power. in my opinion 2.5 inch pipe is good for 400 ponies, probably even more.
- Redcap
