![Embarassed :oops:](./images/smilies/icon_redface.gif)
Fuse box diagram
Fuse box diagram
Any one have a diagram of the fusebox for a '69 F250? Installing a gauge cluster and touched a wire where I shouldn't have and lets just say there was a pop and then some smoke. Looking at the fuse box all the fuse were good except one which had been replaced by a metal clip by previous owner so I've probably fried something else as my lights don't work any more. ![Embarassed :oops:](./images/smilies/icon_redface.gif)
-Braden Day
1969 Ford F-250 4x4 Highboy
1987 Chevy 4x4 1/2 ton
re: Fuse box diagram
Here's the diagram you requested, straight from the '69 owner's manual:
![Image](http://www.fordification.com/board/fusebox-diagram_69OM.gif)
However, as you can see from this diagram, there is no fuse for the headlights. They have a circuit-breaker which is built into the headlight switch. Here is the page from the owner's manual which lists the fuses and bulbs for your truck:
![Image](http://www.fordification.com/board/fuses_69OM.gif)
Normally a circuit breaker will reset itself after a cool-down period. Have you tried it again to see if your lights are working now? If not, I'd guess you fried the switch. What wire did you accidentally ground out?
![Image](http://www.fordification.com/board/mysig.jpg)
![Image](http://www.fordification.com/images/forum/supercab-avatar1.jpg)
![Image](http://www.fordification.com/images/forum/bug.gif)
I'll go try it again but I think, judging by the smoke, I may have fried it. I grounded a blue/red wire from the light switch.
-Braden Day
