#08 - Jan 30, 2007
#08 - Jan 30, 2007
OK, this pictures shows 4 items that are found on a lot of trucks, but not all. Actually, all trucks have similar items, though they vary depending on how the truck is optioned. (I can't say any more without giving it away.) These are roughly 1/2" in diameter.
Last edited by FORDification on Tue Jan 30, 2007 10:38 pm, edited 2 times in total.
- xxxtina63
- Heavenlyfire
- rjewkes
Leaf spring hanger/shackle Eye Bushings.
fuelly.com
fuelly.com
- kknip
re: #8 - Jan 30, 2007
Think they are bushings for the flex o matic rear springs.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- FoMoCo
They look like cylinder head dowls to me.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- theskytoucher
I think FoMoCo got it!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- Big D's 69
Yep I think he nailed it with the head dowels.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
- 67highboy
I think they are cyl head dowels too....
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
- ICEMAN6166
me too.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
- 390Nut
Those are FE cylinder head dowels...
`69 F100 390 4spd driver
Yes, FoMoCo got it right ...those are the dowels inserted into the deck of the block for locating the cylinder heads.
FYI: All Ford I6's and small-blocks (302/351/400) use the same, and FE's and 335's (429/460) use another. The ones pictured above are the FE/335 style.
