light switch or dimmer switch
yes my headlights they will start flickering off and on staying off for 2-3 seconds mainly on high beam when i got to low beam every once in a GREAT while but on high beam all the time plz help
Sounds like the dimmer switch to me... or a ground. Dimmer switch is like 9 bucks at any autoparts store.
Easy fix.
Patrick
Easy fix.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: light switch or dimmer switch
Do you have halogen headlights? If so, install a relay switch. If not, check dimmer switch, headlight switch, bad ground or short. Most likely dimmer switch because you say it happens on high beam and seldom on low beam.
The headlight switch has a built-in circuit breaker, which is what sounds like is causing your lights to cycle off and on. Too much current is flowing through the switch and tripping the circuit breaker, which then resets and then the cycle repeats. Like DuckRyder stated, halogens take more juice and could very possibly overload the switch, which is why you should use the remote relay.
![Image](http://www.fordification.com/board/mysig.jpg)
![Image](http://www.fordification.com/images/forum/supercab-avatar1.jpg)
![Image](http://www.fordification.com/images/forum/bug.gif)
- adrianspeeder
You can easily build a relay controled headlight circuit in an afternoon with 20bucks worth of materials. Radio shack has the needed single pole relays for 6 bucks.
Basicly the stock wiring and switch only has to handle the few milliamps to trigger the relay. Then a direct fused circuit from the battery is closed giving max voltage to the lights. Really makes a difference on these older trucks, and even the newer ones where ford skimps on the wiring gauge size.
Here is a diagram I designed.
![Image](http://www.supermotors.net/getfile/405405/original/relay-controlled-headlights.jpg)
If needed I can do a full photo writeup on the harness build or go into more depth of relay operation.
Adrianspeeder
(gotta love being an electrical engineering major)
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
