http://cgi.ebay.com/ebaymotors/ws/eBayI ... Track=true
Can someone tell me where that goes, what it plugs into? Been trying to figure out why my reverse lights don't work. Might need that piece but not sure.
Could be a problem with my netural safety switch too... its bypassed with
the connector from a manual trans truck.
Patrick
Reverse light switch
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: Reverse light switch
The one in that auction is for manual 3-spd columns only. It gets mounted down at the very base of the column, in the engine compartment.
![Image](http://www.fordification.com/board/3spd-column_backup-switch.jpg)
Trucks with automatics had the neutral safety switch mounted at the base of the column inside the cab.
![Image](http://www.fordification.com/board/neutral-safety-switch.jpg)
![Image](http://www.fordification.com/board/mysig.jpg)
![Image](http://www.fordification.com/images/forum/supercab-avatar1.jpg)
![Image](http://www.fordification.com/images/forum/bug.gif)
- wildcard
My 71 has the switch at the base of the column, but someone put a floorshift in it and now it doesn't have the BU lights connected. Does anyone have any ideas where and how to mount one?
It has the old INDY shifter in it
![Confused :?](./images/smilies/icon_confused.gif)
I looked in your 'My Info' box but see you don't have the transmission listed (hint hint)
....so what type of tranny do you have?
Regardless, you should be able to get a backup switch for that Hurst from any speed shop, or I'd imagine you could also get it from places like Jegs, Summit, etc.
![Wink ;)](./images/smilies/icon_wink.gif)
- wildcard
Build sheet says it's a 3 speed ford manual transmission.But it also calls for a 240 engineand I know it was replaced with a 300 so kinda iffy as to whether the trans has been changed. Got it in the profile now. Thanks ![Embarassed :oops:](./images/smilies/icon_redface.gif)
Here's the necessary page at Jegs:
http://www.jegs.com/webapp/wcs/stores/s ... ryId=10627
However, I see that the two kits they have aren't specifically for your shifter, though the top one is basically what you have, although I'm not sure whether those could be adapted for yours or not. The PDF installation instructions for this same shifter at Summit also shows that the backup light switch is Part # 248 0003, which coincides with the Jeg's description, so I'm guessing it'll work.
